I
Ibrar
Ciao a tutti
può un corpo di convertire i seguenti codici per l'assemblaggio.Questi codici sono per jhd12864 GLCD.
Grazie
# include <reg51.h>
# include <intrins.h>
UCHAR typedef unsigned char;
typedef unsigned int uint;
sbit L_DI = P2 ^ 0;
sbit L_RW = P2 ^ 1;
sbit L_E = P2 ^ 4;
sbit L_CS1 = P2 ^ 6;
sbit L_CS2 = P2 ^ 7;
sbit L_SET = P2 ^ 3;
sbit TEST = P3 ^ 5;
float abc;
X1 codice UCHAR [] = (
0x30, 0x50, 0xd0, 0x90, 0xF0, 0x30, 0x80, 0x60, 0x3C, 0xE8, 0x20, 0xA0, 0XE0, 0x70, 0x00, 0x00,
0x04, 0x06, 0x03, 0x11, 0x13, 0x12, 0x18, 0x0c, 0x07, 0x01, 0x03, 0x06, 0x0c, 0x1C, 0x18, 0x18
X2 codice UCHAR [] = (
0x40, 0x58, 0x58, 0xd0, 0x10, 0xf8, 0x98, 0x08, 0x88, 0xf8, 0xF0, 0x10, 0xf8, 0x70, 0x00, 0x00,
0x0c, 0x04, 0x04, 0x07, 0x04, 0x05, 0x0D, 0x0D, 0x08, 0x1f, 0x1b, 0x19, 0x38, 0x38, 0x18, 0x18
X3 codice UCHAR [] = (
0x30, 0x30, 0xf8, 0xf8, 0x08, 0x10, 0xd0, 0x50, 0x50, 0xFC, 0xFC, 0x50, 0xd0, 0xF0, 0x10, 0x00,
0x00, 0x00, 0x1F, 0x1F, 0x10, 0x10, 0x13, 0x1b, 0x0F, 0x07, 0x05, 0x0D, 0x09, 0x19, 0x38, 0x18
X4 codice UCHAR [] = (
0x00, 0x00, 0x00, 0x00, 0xFC, 0xf8, 0x48, 0x48, 0x48, 0xf8, 0xf8, 0x48, 0x48, 0x48, 0xFC, 0xf8,
0x10, 0x10, 0x18, 0x1E, 0x0F, 0x01, 0x01, 0x01, 0x01, 0x3f, 0x1f, 0x01, 0x01, 0x01, 0x3f, 0x3f
X5 codice UCHAR [] = (
0x18, 0xFC, 0x08, 0x48, 0x48, 0xB8, 0xd8, 0x58, 0xE8, 0xB8, 0xB8, 0x08, 0x08, 0xf8, 0xf8, 0x00,
0x00, 0x1f, 0x11, 0x11, 0x11, 0x14, 0x15, 0x16, 0x16, 0x10, 0x11, 0x11, 0x11, 0x3f, 0x1f, 0x00
X6 codice UCHAR [] = (
0xC0, 0xC8, 0xC8, 0xf8, 0xf8, 0xC8, 0xf8, 0xf8, 0xC8, 0xC8, 0x00, 0x10, 0x90, 0xd8, 0x48, 0x48,
0x18, 0x18, 0x0c, 0x0F, 0x03, 0x00, 0x1F, 0x1F, 0x10, 0x10, 0x11, 0x19, 0x18, 0x0c, 0x04, 0x06
X7 codice UCHAR [] = (
0x00, 0x00, 0x00, 0XE0, 0XE0, 0x40, 0x40, 0x7C, 0x7C, 0x58, 0x58, 0x58, 0xd0, 0xd0, 0x00, 0x00,
0x10, 0x18, 0x08, 0x0D, 0x03, 0x19, 0x0D, 0x01, 0x01, 0x0D, 0x19, 0x01, 0x07, 0x0c, 0x18, 0x38
X8 codice UCHAR [] = (
0x08, 0xf8, 0xf8, 0x48, 0xE8, 0x98, 0x90, 0xd8, 0xF0, 0xbc, 0xFC, 0xd0, 0x90, 0x90, 0x90, 0x10,
0x00, 0x3f, 0x1f, 0x02, 0x03, 0x05, 0x06, 0x07, 0x07, 0x06, 0x3f, 0x3f, 0x06, 0x06, 0x04, 0x04
X9 codice UCHAR [] = (
0x10, 0x08, 0x1C, 0xfe, 0x00, 0x00, 0x00, 0x00, 0x00, 0x30, 0x08, 0x04, 0x04, 0x98, 0xF0, 0x00,
0x80, 0x80, 0xff, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xA0, 0XE0, 0x90, 0x8A, 0x83, 0xC1, 0x00
); / * 12 * /
X10 codice UCHAR [] = (
0x00, 0x78, 0xC8, 0x84, 0x04, 0x84, 0xf8, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80,
0x00, 0x78, 0x84, 0x83, 0x83, 0x8E, 0xFC, 0x40, 0x00, 0x80, 0x63, 0x17, 0x1C, 0xF2, 0xC1, 0x80
); / * 8x * /
X11 codice UCHAR [] = (
0x00, 0x80, 0XE0, 0x10, 0x08, 0x04, 0x04, 0x00, 0x00, 0x00, 0x80, 0x60, 0x10, 0xf8, 0x00, 0x00,
0x00, 0x7f, 0xC2, 0x81, 0x81, 0x81, 0x7f, 0x18, 0x00, 0x0e, 0x09, 0x08, 0x08, 0xff, 0x08, 0x08
); / * 64 * /
X12 codice UCHAR [] = (
0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA, 0x55, 0xAA,
X13 codice UCHAR [] = (
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
X14 codice UCHAR [] = (
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
X15 codice UCHAR [] = (
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
X16 codice UCHAR [] = (
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80
X17 codice UCHAR [] = (
0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
X18 codice UCHAR [] = (
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff,
X19 codice UCHAR [] = (
0xff, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
UCHAR codice X20 [] = (
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0xff,
X21 codice UCHAR [] = (
0xff, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80
X22 codice UCHAR [] = (
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0xff
X23 codice UCHAR [] = (
# pragma REGISTERBANK (0)
void initcomm (void)
PCON = 0x80; TMOD = 0x21; SCON = 0x50;
TH1 = 0xFA; TL1 = 0xFA; TR1 = 1; ES = 1;
TH0 = 0; TL0 = 0; tr0 = 1; ET0 = 1;
EA = 0;
void delay (void)
UCHAR i, j;
abc = 0,1 * 5;
for (i = 0; i! = 0xff; i )
for (j = 0; j! = 0xff; j );
void LCD_C_D (flag bit, ldata UCHAR) / * = 1 bandiera con flag = 0 dati * /
UCHAR i dati;
L_DI =! Bandiera; L_E = 0; L_RW = 0; P0 = ldata;
_nop_ ();
L_E = 1;
_nop_ (); _nop_ ();
L_E = 0; L_RW = 1; L_DI = 1;
for (i = 0; i <10; i );
void dis_one_zi (UCHAR x_add, UCHAR y_add, codice UCHAR * PO)
UCHAR i, j, w;
j = x_add * 2 0 xb8;
w = (y_add <4? y_add: y_add-4) * 16 0 x40;
L_CS1 = (y_add <4);
L_CS2 =! (Y_add <4);
LCD_C_D (1, j);
LCD_C_D (1, w);
for (i = 0; i <32; i )
if (i == 16)
LCD_C_D (1, j 1);
LCD_C_D (1, w);
LCD_C_D (0, * po );
L_CS1 = L_CS2 = 0;
void CLRLCD (numero UCHAR)
UCHAR dati i, j;
L_CS1 = L_CS2 = 1;
for (i = 0xB8; i <0xC0; i )
LCD_C_D (1, i);
LCD_C_D (1,0 X40);
for (j = 0; j <0x40; j )
LCD_C_D (0, numero);
L_CS1 = L_CS2 = 0;
void main (void) utilizzando 0
UCHAR dati i, j, il numero;
UCHAR codice * p;
initcomm ();
L_SET = 0;
L_SET = 1;
LCD_C_D (1,0 x3e );/**/
LCD_C_D (1,0 xc0 );/**/
LCD_C_D (1,0 X3F );/**/
CLRLCD (0);
while (1)
CLRLCD (0);
LCD_C_D (1,0 x3e);
X15 p = ;/*????*/
for (number = 1; numero <7; numero )
(Dis_one_zi (0, numero, p)
p = X16;
(Dis_one_zi (3, numero, p)
p = X17;
for (number = 1; numero <3; numero )
(Dis_one_zi (numero, 0, p)
p = X18;
(Dis_one_zi (numero, 7, p)
X19 = p; dis_one_zi (0,0, p);
p = X20; dis_one_zi (0,7, p);
X21 = p; dis_one_zi (3,0, p);
X22 = p; dis_one_zi (3,7, p);
X1 = p; dis_one_zi (1,1, p);
X2 = p; dis_one_zi (1,2, p);
X3 = p; dis_one_zi (1,3, p);
X4 = p; dis_one_zi (1,4, p);
p = X5; dis_one_zi (2,5, p);
p = X6; dis_one_zi (2,6, p);
p = X7; dis_one_zi (1,5, p);
X8 = p; dis_one_zi (1,6, p);
/ * 128X64 * /
p = X9; dis_one_zi (2,1, p);
X10 = p; dis_one_zi (2,2, p);
p = X11; dis_one_zi (2,3, p);
X23 = p; dis_one_zi (2,4, p);
LCD_C_D (1,0 X3F);
delay (); delay ();
CLRLCD (0);
LCD_C_D (1,0 x3e);
p = X12;
for (number = 0; numero <4; numero )
for (i = 0; i <8; i )
(Dis_one_zi (numero, i, p)
LCD_C_D (1,0 X3F);
delay (); delay ();
CLRLCD (0);
LCD_C_D (1,0 x3e);
p = X13;
LCD_C_D (1,0 X3F);
delay (); delay ();
CLRLCD (0);
Grazie
# include <reg51.h>
sbit L_DI = P2 ^ 0;
sbit L_RW = P2 ^ 1;
sbit L_E = P2 ^ 4;
sbit TEST = P3 ^ 5;
float abc;
); / * 12 * /
); / * 8x * /
); / * 64 * /
EA = 0;
void delay (void)
UCHAR i, j;
abc = 0,1 * 5;
UCHAR i dati;
_nop_ ();
L_E = 1;
_nop_ (); _nop_ ();
UCHAR i, j, w;
L_CS1 = (y_add <4);
LCD_C_D (1, j);
LCD_C_D (1, w);
if (i == 16)
LCD_C_D (1, j 1);
LCD_C_D (1, w);
LCD_C_D (0, * po );
L_CS1 = L_CS2 = 0;
UCHAR dati i, j;
L_CS1 = L_CS2 = 1;
LCD_C_D (1, i);
LCD_C_D (1,0 X40);
L_CS1 = L_CS2 = 0;
UCHAR codice * p;
initcomm ();
L_SET = 0;
L_SET = 1;
CLRLCD (0);
while (1)
CLRLCD (0);
LCD_C_D (1,0 x3e);
X15 p = ;/*????*/
p = X16;
p = X17;
p = X18;
/ * 128X64 * /
LCD_C_D (1,0 X3F);
delay (); delay ();
CLRLCD (0);
LCD_C_D (1,0 x3e);
p = X12;
LCD_C_D (1,0 X3F);
delay (); delay ();
CLRLCD (0);
LCD_C_D (1,0 x3e);
p = X13;
LCD_C_D (1,0 X3F);
delay (); delay ();
CLRLCD (0);
